Przemek211 Posted September 27, 2013 Posted September 27, 2013 (edited) Hello, I updated my DVBV from 5.0 to 5.2.8.1 However the application started to "cutting" ("jamming", "sharping"?) video & audio, especially on HD channels. On SD just sometimes sound sharpes, but on HD i can see few frames of correct video & audio and few next are dropped and over again. The recorded files are working good (HD). The PC doesn't look to be overstained. It doesn't drops frames in filter. I use the Microsoft codecs and EVR. I have totally no idea what can I do or what can I check. Edited September 27, 2013 by Przemek211 Quote
Przemek211 Posted September 28, 2013 Author Posted September 28, 2013 (edited) Really nobody's going to help me? I would like to downgrade for a 5.0 ver, but this is not available in Members Section. ///just about recorded files I mean old files. If I record now something there is similar problem. Ok, I downgrade to the 5.1 (only other available in members) and it works well as in 5.0 Edited September 28, 2013 by Przemek211 Quote
QBox User Posted September 30, 2013 Posted September 30, 2013 You should post a support.zip if you want assistance. It may be coincidence, but I had some video problems after updates last week and had to do a System Restore to recover. Other media players were affected as well as DVBViewer. Quote
Przemek211 Posted September 30, 2013 Author Posted September 30, 2013 Thanks for your answer. I found the reason of problem, however it could be only fixed by DVBViewer team. I think it is just really small bug, but that's sad that nobody say something like: "ok, it will be corrected in next releases of DVBViewer and Rec.srv" or just "we will check that" http://www.DVBViewer.tv/forum/topic/53281-important-bug-some-plugins-recognize-pro-version-as-ge/ Quote
