Support Hardware
I buy to Avermedia Usb Dvbs2 card. Device the ci slots not work, free channels ok but ci slot not decode. I try demo version 5.1.0. Any suggestions? Thanks.
ci slots not work ... I try demo version 5.1.0.
As stated here demo version has a COM limitation...
Any suggestions?
Sure: buy the full version (15€), you won't regret...
:bye:
Please read here, follow all instructions and post here your SupportTool file...
:bye:
Edited by Gioxy
Thanks for your message, i was install the lastest driver the sites but i'll try this driver. Thanks again.
Edit: First i install the drivers cd then update to website.
Edited by Josh_
  • 4 weeks later...
please help me
I've bought the dm04 device dvb-s
It only work with DVBViewer but every time that i change tp it need to restart the DVBViewer and the other tp works great
When I do a satellite search it says no signal to all TP.But i have signal and very very strong (Hotbird 13.0E)
  • 3 weeks later...
Hello everybody,
Please give me a hand with my DVBViewer Pro that doesn't see a CAM inserted in TBS 5880. What should I get and do? Thanks in advance.
i think, that is 5980, not 5880... I used that dvb-cards & aston cam with seca - be sure, that you installed latest drivers http://www.tbsdtv.com/download/ in DVBViewer hardware: S2 & CAM - what system? smart-cards is active? is working with tv, or another dvb?
Thank you for your attention, but I've solved this problem already. DVBViewer can see CAM if during the installation you choose support for CI on the Component Download page and tick the appropriate boxes. Now my TBS 5880 DVB-T/T2/C CI USB 2 box shows all the encrypted channels which are allowed with my smartcard.
My question now is how can one achieve the same result without reinstallation DVBViewer, if it is possible of course.
I buy to Avermedia 3DTV Usb Dvbs2 card. Device the ci slots not work, free channels ok but ci slot not decode. I try demo version 5.1.0. Any suggestions? Thanks.
