1080jawbreaker Posted October 1, 2013 Posted October 1, 2013 (edited) elecard recently releases a h265/HEVC plugin, could DVBViewer support this? there is a demo channel on astra at 19.2 degrees east 10992H 22000 5/6 QPSK DVB-s2 transedit recognises the h265 video and ac3 audio streams but when scanning into DVBViewer the scan only recognises the audio thanks Edited October 1, 2013 by 1080jawbreaker Quote
Griga Posted October 2, 2013 Posted October 2, 2013 Though the stream type in the PMT (0x27) indicates HEVC, the stream does not comply with the H.265 specifications. Nobody knows what it actually is, and no HEVC decoder is able to decode it. Quote
1080jawbreaker Posted October 2, 2013 Author Posted October 2, 2013 Though the stream type in the PMT (0x27) indicates HEVC, the stream does not comply with the H.265 specifications. Nobody knows what it actually is, and no HEVC decoder is able to decode it. elecard have release a hevc plugin and standalone player Quote
Griga Posted October 2, 2013 Posted October 2, 2013 elecard have release a hevc plugin and standalone player Yes, I know. I've already tried it some time ago. It doesn't play the stream mentioned above. Quote
Antonio Posted October 13, 2013 Posted October 13, 2013 TransEdit 3.9.4 now recognises 0x24 HEVC Video. Is there a chance to play with Lentoid HEVC/H.265 Decoder? http://strongene.com/en/hevc/decoder/download.jsp On the Hispasat 1E, 30W satellite recently I earned the Spanish package with a channel broadcasting in full 4K. The broadcasting goes in parallel to H.264 and H.265. Reception parameters: 30W, 10730V, DVB-S2/8PSK, SR 30000, FEC 3/4. record of a stream: http://www.ex.ua/159950992547 Video bitrate H.264 - 35.8 Mbps, H.265 - 18.4 Mbps. Quote
Derrick Posted October 13, 2013 Posted October 13, 2013 Is there a chance to play with Lentoid HEVC/H.265 Decoder? not yet Quote
Griga Posted October 13, 2013 Posted October 13, 2013 Is there a chance to play with Lentoid HEVC/H.265 Decoder? I've tried, but unfortunately I can't make it work with the DVBViewer Filter. It's still very experimental, e.g. the video resolution and other parameters have to be hard-coded in the DVBViewer Filter, since it is not yet able to read the HEVC headers. Very complicated, more than H.264. However, the first steps are made - see TransEdit 4.0.4 Header Info function, which is a good preparation and will facilitate further efforts. Sooner or later it will play... Quote
DunnoX Posted October 31, 2013 Posted October 31, 2013 I was able to view a dump from an hevc channel from hispasat "tve 4k" using ffplay from zeranoe ffmpeg 2.1 build. LavFilters will soon have hevc decode, I think k-lite already has. Quote
Griga Posted October 31, 2013 Posted October 31, 2013 LavFilters will soon have hevc decode The latest nightly builds already have. We succeeded in playing some HEVC samples with the DVBViewer Filter as demultiplexer / splitter and LAV Videodecoder in TransEdit and DVBViewer GE (HEVC capable versions not yet released). However, it takes tremendous CPU Power to decode HEVC with 4k resolution by software, since there is no DXVA support from graphics cards. It even pushes an i7 quad core to its limits. Quote
