Cian Posted October 2, 2013 Posted October 2, 2013 (edited) Hi, I'm not sure of there is a plugin for this, but I want to do a recording and then trigger a conversion process so that I can (auto?) copy the file to my mobile for viewing later. I looked at the "After Recording" option in the timer, but there did not seem to be an option to launch any programme. Does anyone have a system they use? ... or is there a system where the recording would be transcoded on the fly, but output to a file rather than the live stream? Tks. C. Edited October 2, 2013 by Cian Quote
Cian Posted October 2, 2013 Author Posted October 2, 2013 (edited) As I look further there may be an option to use ffmpeg. Did not realise the power of it - I thought it was there as a renderer. I will look and see if I can create a schedule task that could do it for me. Maybe someone has an example of this? I guess you would use the Task Scheduler to launch the converter. Edited October 2, 2013 by Cian Quote
