Snapper Posted November 9, 2004 Posted November 9, 2004 Help please Reinstalled my SkyStar2 PCI card on upgraded AMD 2400, and Asrock motherboard PC, Win98, MediaPlayer9, Matrox 450 Dual head video card (worked OK on old AMD 1800) I get good signal strength 70 to 90%, picture comes up on Hotbird NBC Europe (and others) after a minute or so as a still, then changes frames every couple of seconds, with each frame change hard drive is being accessed, have downloaded new SkyAVC.ax as suggested, I have disabled overlay in Setup4PC, none of these seem to make a difference. I think it must have missed something simple! Snapper Quote
Hartwig Posted November 9, 2004 Posted November 9, 2004 Do you use the "speed" patch for win98 from Microsoft?? (I don't know the real name) You need it for win98, if your pc is too fast. Quote
Gioxy Posted November 10, 2004 Posted November 10, 2004 hard drive is being accessed ckeck also if there was Timeshift enabled: is the only thing that can make disk activity if you aren't rec... And, PLEASE, give us ALL necessary info (read here witch...) Gioxy Quote
