Cian Posted November 7, 2013 Posted November 7, 2013 (edited) Hi, I often find myself going back and forth between two stations (or changing channel by accident!!). Could we use the Track Up/Down buttons (labelled Previous Item/Next Item in DVBViewer) to go back to the previous station? They are greyed out in Live TV, so thought they could be used that way. Just a thought, C. Edited November 7, 2013 by Cian Quote
SimonP Posted November 11, 2013 Posted November 11, 2013 Under 'Channel' is an option 'Last Channel' which does what you want but I don't think there's a button available for it, which is a shame as I'd use that quite a lot. Quote
Cian Posted November 13, 2013 Author Posted November 13, 2013 Thanks Simon. I just looked at the Inputs options, and it doesn't seem to be there as an option to have a key assigned to it (but I often miss the really obvious things!!) Quote
Gioxy Posted November 13, 2013 Posted November 13, 2013 ... it doesn't seem to be there as an option to have a key assigned to it... ...why not? I have "Last channel" action associated both to a keyboard key (left cancel) and to a remote button and it simply works... please refer to "Learn" entry in Option Input wiki page to know how to do it. Quote
ThulsaDoom Posted November 14, 2013 Posted November 14, 2013 First things first: You have to create a user command first (choose the Action ID "Last Channel") and then do the learning thing to associate a key and/or rc-button with it. The wiki page Gioxy has linked is a good help ! Quote
Cian Posted November 14, 2013 Author Posted November 14, 2013 First things first: You have to create a user command first (choose the Action ID "Last Channel") and then do the learning thing to associate a key and/or rc-button with it. The wiki page Gioxy has linked is a good help ! Thanks all. I knew about the Learn option, but not about adding actions to the list so that you could assign it! Will give it a go later. Quote
Gioxy Posted November 14, 2013 Posted November 14, 2013 Thanks ThulsaDoom, I completely forgotten that I had added myself this action looong time ago... Cheers and enjoy Quote
