krasno Posted November 14, 2013 Posted November 14, 2013 Hello Anyone else have this problem in Recordservice Windows 8: in Timeline hours are in 24 hours In TV Guide it is AM/PM In Channel EPG it is AM/PM Search EPG it is 24 hours ( Field: Time span ) In Timer AM/PM In Recordings AM/PM Windows settings are in 24 hours system. I have no idea where else to change it.. just in case it is a problem here support.zip are attached.. support.zip
Griga Posted November 14, 2013 Posted November 14, 2013 Maybe a known bug of pre-installed Windows versions. Usually it can be fixed by changing the region settings in the Windows control panel e.g. to some other country or other date/time format -> click OK -> then change it back to what you want -> click OK in order to add missing registry entries.
krasno Posted November 14, 2013 Author Posted November 14, 2013 Well.. I have now been in Thaiti, USA, UK, France and Germany and back in a few min. (I'm really fast..) including restarts, but the problem is still there, not that is not to live with.. Time settings in all other places are correct ( as far as I can see..)
krasno Posted November 14, 2013 Author Posted November 14, 2013 Don't waste time to find another solution, in a way the problem is solved..the bad way, read here: http://www.DVBViewer.tv/forum/forum/1-general-DVBViewer-proge/
