Geoffry Posted November 16, 2013 Posted November 16, 2013 After updating the Digital Devices CineS2 6.5 driver the card can not be found by DVBViewer. Both tuners are enabled in the driver and DVBViewer. The same happens when I disable the JMicron SATA controller in the BIOS from the motherboard. This controller is not in use by any device and slows boot times. Updating or reinstalling DVBViewer to the latest versions does not help.Cleaning the registery did also not solve the problem. Only if I do a restore with an previous image of windows 7 DVBViewer works again. So it is not a hardware problem. Has anybody ideas how I can find a solution? Regards, Jeff Quote
