NIKKOpooh Posted November 28, 2013 Posted November 28, 2013 My card is Mygica x8558Pro with dual tuner. Nearly everytime of reboot (especially after anabnormal shut down). The name of the card in the hardware tab will appears to be red. i have to press "scan devices" to get the card back again. it happens to both the recording services and DVBViewer, Is there anyway to rescan the card automatically? thanks Quote
Tjod Posted November 28, 2013 Posted November 28, 2013 As far as I know it is not possible to auto scan for new hardware. If that happens again copy the hardware.xml from configuration folder to a different folder. Than scan for new devices an after that create a support.zip. And than poste the hardware.xml and the support.zip Quote
