DVBViewer Transponder List
Jake Matchett
There is an option when installing DVBViewer to list channels either by provider, in alphabetically listed folders shown in Channel list or by a list of frequencies with the channel on those frequencies in the folder. I Installed DVBViewer Pro but was not given the choice. How can I change the channel list from provider to transponder/frequency?
Thanks
After spending most of this afternoon searching, I finally solved the problem with TransEdit. Might I suggest that at some point a cross reference is put in DVBViewer or even in the manual (yes I did read it) By the way DVBViewer is a very good piece of software.
