uglyned Posted December 23, 2013 Posted December 23, 2013 Hi, I'm using an MCE remote on my HTPC but it's not quite working with DVBViewer. I have the MCE remote plugin, and the 'learn' buttons in the Input detection work - all the 'special' keys are picked up by DVBViewer. But they dont' work in actual TV watching at all - some do, like the numbers, OK, direction buttons - all the non-'special' ones. But the play, pause etc buttons don't register, even though they've been picked up in the input / learn options. Does anyone know what I can do? Quote
Delphi Posted December 23, 2013 Posted December 23, 2013 For me the attached file works. Unzip to DVBViewer Data Folder\remotes (mce.remote) Then DVBViewer > Settings > Options > Input > Load(button) Maybe you want to change it a bit, then Apply or OK mce.zip Quote
lysergic Posted December 28, 2013 Posted December 28, 2013 I found the latest version 5.2.9 causes this behaviour. Try installing 5.2.8.1, that works for me. Quote
Delphi Posted December 29, 2013 Posted December 29, 2013 Works fine for me with DVBViewer 5.2.9 and the upper file. Quote
-lahna Posted December 29, 2013 Posted December 29, 2013 (edited) 5.2.9 causes mce remote problem me too Edited December 29, 2013 by -lahna Quote
uglyned Posted December 30, 2013 Author Posted December 30, 2013 An update - I reverted to 5.2.8 and the problem is resolved - the MCE button presses are detected when TV is playing. Ironlcally, in 'learn' in the input settings, 5.2.8 does not detect rewind / fast forward presses while 5.2.9 did but a quick edit of the XML file resolved this. Although the 'learn' does not detect the key presses in 5.2.8, they are successfully detected and actioned when watching TV. Quote
mikevd Posted December 30, 2013 Posted December 30, 2013 i use this: http://www.DVBViewer.tv/forum/topic/39857-inputplugin-for-multimedia-keys-incl-sources/ Quote
