BBC Three SD / HD extra file
Eyerex
It's only a minor little thing but when i record BBC Three SD / HD i always get two files one video file plus a extra one which is only a few Kb in size
This is caused by changes in channel settings (PIDs) during transmission. There's a setting Options-Recorder-Auto split on channel data changes that will be checked.
http://en.DVBViewer.tv/wiki/Options_Recorder#Auto_split_on_channel_data_changes
If you scanned when the part-time channel is off-air, PIDs will be set to zero. Actual PIDs are only seen when they transmit. If you re-scan during transmission times, the stored PIDs will be corrected. You could also manually edit the values from a known listing (kingofsat, etc).
I guess he's using the Recording Service, so the channel data doesn't get corrected and it happens again and again. Or Channel -> Auto-Update Channel is switched off in DVBViewer.
Since Eyerex doesn't provide any useful information about his setup, guessing is all we can do. Many people are simply not able to write meaningful bug reports >_<
Oops my bad
PCTV 290e Driver 5.2010.901.0
GIGABYTE Sniper M3 Z77 Express Chipset
GeForce GTX 660 Driver 331.82
