Realtek DVB-T+DAB+FM USB
loguey
I recently purchased one of these sticks to try out the DAB module but find it won't work.
I've installed the stick with the drivers supplied. My PC runs Windows 8 64 bit, and does recognise the stick as does DVBViewer. It appears in DVBViewer as a Realtek 2832U terrestrial tuner. However when I run a terrestrial scan on all terrestrial channels the scan jumps straight to UHF channel 68 and says no channels found.
I suspect the problem is my 64 bit Windows. Does anyone have 64 bit drivers for this stick?
  • 1 month later...
you're right.
this rtl-2832 tuner (sells at 10 Euro at ebay) works excellently in WinXP-32 but even with the blaze decoder I found no TV or Radio under Win8.1-64.
sdr works like a charm in win8.1-64.
the zadig driver for the rtl2832u works in win 64bit and allows sdr apps to use the stick.
