elvis-c Posted January 25, 2014 Posted January 25, 2014 Hi, trying to install Recording Service, but Kaspersky Anti-Virus 2012 shows warning: "Process is performing suspicious actions" Detected: PDM.Worm.P2P.generic Process (PID: 3884): C:\USERS\ELVIS\DOWNLOADS\SVC_SETUP_1.28.0.EXE ----------- I get the same warnings on 1.26 and 1.28 Recording service versions. Kaspersky just deletes the installed files and recording service doesn't work.
Tjod Posted January 25, 2014 Posted January 25, 2014 The heuristic thinks it detects something even if there is no Virus. https://www.virustotal.com/de/file/e3f19094e80fe2c00c3ab605de5e74789ada70542b6bd86ef5d5a81bdac16cd6/analysis/1390648471/ You could call it a Bug in Kaspersky Anti-Virus 2012.
elvis-c Posted January 27, 2014 Author Posted January 27, 2014 OK. Thanks for your reply will upgrade Kaspersky then.
