'Live' streaming to LG SmartTV
jmra
Hello,
I would like to know if its possible to live stream from DVBViewer to a LG smarttv (it supports DLNA), meaning I would like to see in the tv what is viewed in DBViewer.
I have the PC in one room and the tv in another room and both are wire connected to the same router/network.
Thank you.
Best regards.
You need to run the Recording Service, with UPnP AV Server enabled. As long as the router supports multicast, the TV should see the server.
