azimli Posted August 18, 2014 Posted August 18, 2014 Dear @Tjod,What is the opinion of this file that you obtained?Regards. Quote
Tjod Posted August 18, 2014 Posted August 18, 2014 My assumption was not confirmed. And if it works in 3.9.5 and not in 4.0.7 I have no idea. Quote
serkanguzel Posted January 22, 2015 Posted January 22, 2015 With version 4.0.8, can not still exported. Quote
serkanguzel Posted January 22, 2015 Posted January 22, 2015 Pleas post a support.zip Does not matter ! Because the problem in 4.0.7 and continues in this release. @griga said, "to be investigated," he said. What happened ? 4.0.0 and 4.0.1 are exported. Not exported after. Solve that problem anymore ... Quote
serkanguzel Posted March 10, 2015 Posted March 10, 2015 With version 4.1.0, can not still exported. Quote
tuck Posted March 10, 2015 Posted March 10, 2015 no problem here there is something wrong with you system you should reinstall windows an redownload DVBViewer and transedit from the members section or in short fix your system there is no problem in transedit Quote
Griga Posted March 10, 2015 Posted March 10, 2015 With version 4.1.0, can not still exported. Sorry for that, but I don't know why it happens on your PC. It was investigated, but there is no evidence for a bug in TransEdit. It works here, for all beta testers and several users without problems. Quote
Antonio Posted March 10, 2015 Posted March 10, 2015 I have a slow start version 4.1. Goes somewhere 3 seconds after I click on the icon, then see the main application window. In version 4.0.8 immediately, less than 1 second. something has been changed? Quote
Tjod Posted March 10, 2015 Posted March 10, 2015 Here is the start 2 sec. slower as well. But I don't think that is a real problem. And there have been a lot of changes in this version. http://www.DVBViewer.tv/forum/topic/2745-transedit/?p=424382 Quote
serkanguzel Posted March 10, 2015 Posted March 10, 2015 Yes, yes mate. Export okay. Re-Install DVBViewer and result ; I thank the contributors. Best regards. 1 Quote
