DVBViewer: Pictures turn around
uadler01
I have the DVBViewer with a Technisat Sky-2 DVB-S card.
When I see an channel after a few moments the pictures ar turn around (180 °).
I have to reload the channel and then the pictures are correct for a few moments.
With this problem it is not possible to record a movie, because the pictures of the movie are turn around.
I hope anybody have an workaround.
Thanks Uwe
Edited by uadler01
have you installed any codec-packs?? That might be the fault.
Mostly due to installed codec packs. It is strongly recommended to leave them alone, cause usually it's a hard job to make the PC work properly again. I guess you are German, so have a look here.
i remember me to an "joke"-virus which could turn the screen.
I hopw you are virus free ...
