satdown Posted February 9, 2014 Posted February 9, 2014 I am just trying to write my first autohotkey program. I am processing channels.dat and comparing it against area/regional channel information(Logical channel numbers) from EPG Collector, eventually I hope to update the channels.dat with changed information according to LCNs, I have a few small problems with the channels.dat format. I downloaded DVBViewer_File_Structures.zip from the customer area, the channels.dat format doesn't seem to be up to date :- Orbital position is marked as reserved 5 in channels.dat documentation, language is marked as reserved 7 and 8. When exporting a channel list via the channel editor I can't work out the positions or settings for the of following fields : lnbselection, epgflag, volume, audiochannel and substreamid. I am attempting to process all the channels for a particular root which I have called called "Astra 28.2 E", this seems to work fairly well except that a few channels have a root of "Astra 28.2 E" followed by bel(hex 07) then "d (ben)", the string "d (ben)" appears to come from a channel name "Sky News Active iText Quad (ben)” note this name is exactly 26 characters in length which is the maximum name size, a few other channels seem to have a similar problem when their channel name is 26 characters. I can work round this using substrings – but it does seem to be a problem. Could someone also let me know how I recognise a channel as compared to a subchannel where nid,sid and tid are the same, currently I am looking at audio pid and if I find a duplicate, I am assuming it is a new channel. Quote
satdown Posted February 9, 2014 Author Posted February 9, 2014 Just realised that the hex characters 07 etc in name and root mean that the end of the root should be appended to the name Quote
satdown Posted February 11, 2014 Author Posted February 11, 2014 Found the subchannel (audio) flag, in the flags byte, I should now be able to swap channels so that my preferred language is always the first channel i.e. "eng" rather than "NAR" Quote
