DVBserver more transpoders
m4r3k001
hi
i don't know if here is a similar question,but i havent found it.
i have try'd to configure a streaming server but only with demo version (or maybe some old pirate version) and it work ok,but only trought unicast,and i don't want to configure trought brodcast without the pro version that i will buy someone can confirm my problem.
when i buy the pro DVBViewer can i insert maybe 3 skystar2 pci card's and with every card to stream another transpoder.
let as say
1. ss2 - pro7,sat1 and so on
2. ss2 - ard,kika
3. ss2 - viva
or maybe 3 diferent card like ss2, ss2 usb, hauppage and so on..
will it work like this or does the dvbserver have only 1 card that can stream?
and how much of traffic produce 1 channel?
from unicast i have see like 6Mbps,and is it possible to somehow change the resolution so that will send like 2Mbps?
tnx for the awnser,but the question is still the same...
only this time everything is recorded and stream trought lan/net
but can you record the entiry transponder with like 5 channels?
