Rob66 Posted March 1, 2014 Posted March 1, 2014 (edited) I am using DVBViewer 5.2.9.0 > TBS 6928SE DVBViewer can't find the TBS 6982SE Device... Do you have a advice? Thx Rob66 support.zip Edited March 1, 2014 by Rob66 Quote
Derrick Posted March 1, 2014 Posted March 1, 2014 ..it seems that the installation is not complete. Please run setup again and post a fresh support.zip Quote
Rob66 Posted March 1, 2014 Author Posted March 1, 2014 Done, I Unstall in "Programs and features" DVBViewer. I download DVBViewer Pro 5.2.9 from site en install it again. Result is the same... hereby the new support.zip. file.. support.zip Quote
Derrick Posted March 1, 2014 Posted March 1, 2014 ..same, essential files are missing. Try again as administrator. Quote
Rob66 Posted March 1, 2014 Author Posted March 1, 2014 I am running my system, as administrator I blind my name... Quote
hdv Posted March 1, 2014 Posted March 1, 2014 Derrick means right click on the setup.exe -> run as admin for installation of DVBViewer Quote
Rob66 Posted March 1, 2014 Author Posted March 1, 2014 Done "Run as Administrator" Result The same can't find the TBS 6928SE Card... Fresh Support file support.zip Quote
Rob66 Posted March 1, 2014 Author Posted March 1, 2014 >Maybe your card is unknown to DVBViewer.. I agree, the BDA driver is not recognize. So I have change the card to the old one TBS 6928 (without SE) Now DVBViewer scan my device is working perfect, problem for the moment solved I will inform TBS about this problem For all, thanks for helping my with this problem.. Best regard, Rob Quote
