bogdan1980 Posted March 4, 2014 Posted March 4, 2014 (edited) Tittle say everything,KEYS not working in Fullscreen "ENTER" key for OSD MENU not working in Fullscreen, same for ESC key. Same for Mute, same for all keys. Only working in window mode. If i watch tv in DVBViewer window, i could click Enter, and menu appear. If im in fullscreen, enter key doesnt work at all, no reaction. Anyone help? Without uninstall and reinstall? Something happen that broke keys in fullscreen, almost all keys not working. thanks. Edited March 4, 2014 by bogdan1980 Quote
bogdan1980 Posted March 4, 2014 Author Posted March 4, 2014 I was forced to uninstall and install an fresh copy, because on an stupid error with online.dll, and still not working. SO i think that its something in latest DVBViewer 529 version, an bug. Quote
QBox User Posted March 4, 2014 Posted March 4, 2014 Sounds like the window has lost focus. I don't use OSD much, but sometimes need to click mouse on the screen to regain focus for remote commands. Quote
bogdan1980 Posted March 6, 2014 Author Posted March 6, 2014 i use win7 64, amd fx8350, gigabyte 990fxa ud3 board. I double click DVBViewer for fullscreen, then click ENTER or any other keys, its not working. I tested with xbox360 gamepads mapped as keyboard, not working as well. tested with remote mce, same. But in window mode is perfect. Quote
QBox User Posted March 6, 2014 Posted March 6, 2014 Maybe another process is taking focus. If you can't work it out, you could try the plugin linked from this thread: http://www.DVBViewer.tv/forum/topic/52211-always-on-top-not-always-on-top-loss-of-focus/ From the German thread, there's an option for "fullscreen only". Quote
bogdan1980 Posted March 7, 2014 Author Posted March 7, 2014 I find the fix after few months ...... in DVBViewer- Options -Appearence at Skins, i was set to NO SKIN. This cause the bug with no keys working in fullscreen. If i set to DEFAULT SKIN or DEFGOLD all keys are working. Anyone could test this? DVBViewer- Options -Appearence , set SKIN to NO SKIN. Stupid bug , im 100% its appear in latest version. Quote
Griga Posted March 7, 2014 Posted March 7, 2014 Anyone could test this? DVBViewer- Options -Appearence , set SKIN to NO SKIN. Not reproducible here. Quote
