Demo worked ok Full version Black screen and Error Message
Dobbin231
Hi
The demo version worked great so I paid for the full version, downloaded and installed it.
Now on startup I get the following error message
DVB Viwer Pro Error
Cannot render Mediafile/Output.Pin, error: 0x8007007E. The specified module could not be found.
And now the screen is black though I ge sound.
This has now affected the DEMO version as well.
I saw the FAQ about black screen with sound.
I tried the Options->DirectX but couldn' see anywhere that said "output" under Options->DirectX or "Unchanged" or "VMR".
Started off thinking he software was perfect for me but now no so sure.
Any idea what has gone wrong and how I can fix it?
  • Like 1
  • 10 months later...
I have exactly the same problem with UK Freeview SD channels, although the HD channels are fine.
Hi, thanks for the reply. However I managed to get a result myself by changing the MPEG2 filter from Cyberlink to AMD. I'll check out the LAV filters as well.
