Favorites.xml
fitze11
Just a quick one, I'm updating my favorites within the viewer but when I look in the favorites.xml file it's not updatng the file, it seems to be the standard favorites that came with dvbviwer. I'm using recording service and XBMC dvb client which has the option of loading channels from the favorites file. Would be great if I could get this file updating, I'm probably doing something really stupid.
hi fitze11,
you have to use the favourites.xml in the configuration folder not in the program folder, right?
you can open the configuration folder about DVBViewer Pro -> Help -> Configuration Folder
Thanks for the help, I was using incorrect favorites file. I was looking at the one in the program files.
