Taskolle Posted March 14, 2014 Posted March 14, 2014 I Use cyberlink video decoder.i cant get DXVA to work. When i press DXVA and "apply" and "ok" When i go in there again the SW is selected. What to do? Quote
hdv Posted March 14, 2014 Posted March 14, 2014 http://translate.google.de/translate?hl=de&sl=de&tl=en&u=http%3A%2F%2Fde.DVBViewer.tv%2Fwiki%2FOptionen_DirectX%23..._2 go to the chapter 4.1 sometimes the videodecoder don't accept changes if the decode a stream. if you watch TV in DVBViewer Pro first make View -> Stop Graph or start DVBViewer without playback a channel. then go to Options -> DirectX -> and on the right side of the Filter selection use the ... Button. there you can tick DXVA -> OK and the select a TV channel or playback a file Quote
