Installing only Recording sevices without DVBViewer?
lujo
I want to install Recording services on my Windows Home Server v1. Is it possible to install this service without DVBViewer application on this server?
On my main Windows pc I will install DVBViewer to scan for channels.
Is this the best version what I need to use? Is there any "stable" not beta version?
Description: DVBViewer Recording Service ( 8498 Downloads )
» Version: Version 1.28 Beta
» Size: 4787 KBytes
» Last Updated: 24.12.13
Edited by lujo
» Size: 4787 KBytes
It is not possible to install Recording Service, without DVBViewer installed. Recording Service use some of the resources from DVBViewer.
Recording Service has always been Beta, but my experience is that all versions has been very stable.
I guess in principle yes, though I don't know whether the licensing system works with a RS installation without DVBViewer.
Which one should that be? Maybe the channels.dat :rolleyes:
Installing the DVBViewer is necessary,
The RS has no channel list management capabilities.
As i remenber Recording Service will not install if DVBViewer is not installed. But why is this an issue. Just install DVBViewer!!!
You need it anyway to scan channels (you can of course use transedit, but you need to import it to DVBViewer, before you can use it in Recording Service)
..not an issue but a question ;)
..even worse, it doesn't support favorites.
Recording Service has always been Beta..
IMHO it's time to make RS a fully self supporting application with channel management etc. via a new web server :D
You have to install BDA support first.
NO, both WHS-Versions (V1 & 2011) work without a seperate installation of BDA-support!
..gut zu wissen, werde ich aber wohl beim nächsten mal wieder vergessen. Vielleicht erinnere ich mich dann aber trotzdem noch, nicht mehr auf Windows Server zu reagieren ;)
Google trans: .. good to know, but I'll probably forget the next time. Maybe I remember the people still, not on Windows server to respond
