juissinen Posted March 17, 2014 Posted March 17, 2014 Hello! I've been using DVBViewer many years. It's worked very well. Now i have try recording service and i have problem. I have one satellite dish and it has two LNB. One for the Hotbird and one for the Astra. In channel search window it say "no hardware found". The service shows all channels from both satellites in channel list. When i try to watch channels. Astra channels not works. Only a black screen and signal is 0%. HotBird channels works fine. HotBird is Pos A/Opt A. Astra is Pos B/Opt A. I also have two cable cards. They works fine. I hope, that someone can help. support.zip
QBox User Posted March 17, 2014 Posted March 17, 2014 Sounds like your LNB switch is not working. Is it DiSEqC? First thing to try is the alternate settings PosA/Opt B or Pos B/Opt B for Astra 1. What setting did you have working on DVBViewer Pro? You only have one RTSP device set-up on the client, for the DVB-S device. You will need to set up a separate one for DVB-C.
juissinen Posted March 17, 2014 Author Posted March 17, 2014 Alternate settings works!!! Thank you very very much!!
