Updating server from the client
lujo
Is it possible to add button so that Client pc can update alle channels data on the server with one cclick on the button "Update channels on server"?
At this moment I have understood that I need to move channels.dat and favorites.xml file to the server (Configuration folder of Recording service).
yes, best is:
first stop the RecordingService
then copy/move the channels.dat/favorties.xml (but RecordingService not use the Favorites)
start the RecordingService again
updating directly ist not possible now
I am manageing it the opposite way. I maintain the channels and favorite on the server, with DVBViewer on the server. On the clients i use a batch file to copy channels and favorites to the client, then starts DVBViewer. To use this code, you need to modify to macth your folder and server name
Batch file:
tasklist /FI "IMAGENAME eq DVBViewer.exe" 2>NUL | find /I /N "DVBViewer.exe">NUL
if "%ERRORLEVEL%"=="0" goto running
goto notrunning
:running
rem Program is running, kill it
Taskkill /IM DVBViewer.exe /F
goto copyfiles
:notrunning
rem Program is NOT running
:copyfiles
Rem TAKE CARE! The files will be overwritten without a prompt. If you want to have a prompt, remove /Y
xcopy \\Server\c\ProgramData\CMUV\DVBViewer\channels.dat C:\ProgramData\CMUV\DVBViewer /Y
xcopy \\Server\c\ProgramData\CMUV\DVBViewer\favourites.xml C:\ProgramData\CMUV\DVBViewer /Y
rem start DVBViewer
"C:\Program Files\DVBViewer\DVBViewer.exe"
Why dont you just use the option to download the channels and favorites from the server in the client settings?
http://en.DVBViewer.tv/wiki/Options_Recording_Service
My way is more excotic, and exciting!!!
No, kidding. You are rigth. I didnt now this, and i will use it in the future. Thanks for the tip!
