Hauppage HVR-5500
el_domingo
I just started to use HVR-5500 Hybrid DVB-S2,DVB-C/T2.
My problem is changing cable channels took too much, more than 4 seconds (different frequencies).
DVB-S2 channels change is good there is no problem at all.
Latest driver and DVBViewer 5.2.9 is running in win7 x64.
What can I do ?
Okay I found reply by myself. Rescan with right modulation (not auto) corrected the problem.
Old channels found by old Terratec Dvb-c Pci card and with auto modulation.
i also does that on all my cards, usb stick, pcie, etc, i scan with qam 64 and qam256, not auto.
But this problem is only on DVBViewer, on progdvb/dvbdream, channel swich is ok on auto qam.
