Reassign an EPG
Cian
On some channels, the SD version of some channels has 7 days of EPG but only now and next on the HD version. Is there some way of changing the settings on the channel (Stream ID or Service ID?) that will make it apply the SD EPG to the HD channel?
Thanks,
C.
Edited by Cian
no its not possible, this are two different channels and you cant mix it. You must use external tools for it.
PeterF
