How to get dvbvkey file
xBlacknightx
~~ Solved ~~
Edited by xBlacknightx
  • 3 years later...
On 2017/11/17 at 9:08 PM, Webturtle said:
你好,
你可以在这里找到:C:\ Program Files(x86)\ Common Files \ DVBViewer Shared \或者写一封邮件给Hackbart(http://www.DVBViewer.com/de/index.php?page=lost)或者使用电路板的搜索功能。
许多问候
Webturtle
对不起,我的计算机上没有那个文件夹,我也写信了,但是收到的信中没有那个文件,不知道怎么搞
Please try this path:
C:\Program Files\Common Files\DVBViewer Shared\
The path depends upon x86/x64 OS ;)
You should not put the manually in the DVBViewer Shared folder
Use the KeyTool for it.
