dvbrewer Posted April 21, 2014 Posted April 21, 2014 Is there a way to get mini EPG to show 4 character time i.e. 10:21.....11:23 .....12.24, rather than limiting to three numbers? Quote
Tjod Posted April 21, 2014 Posted April 21, 2014 It sounds like the OSD Skin you are using requires a different font that is not installed in your system.And the fall-back font is bigger and there is not enough space in the time field. Quote
dvbrewer Posted April 22, 2014 Author Posted April 22, 2014 It sounds like the OSD Skin you are using. Requires a different font. Which is not installed in your system. And the fall-back font is bigger and there is not enough space in the time field. It is even worse with Default or Default wide skin, it only shows 10:..., with Envy skin it shows 10:0... Quote
Tjod Posted April 22, 2014 Posted April 22, 2014 The Default OSD Skin is designed to work with "Arial Narrow". http://www.DVBViewer.tv/forum/topic/47984-osd-question/ Quote
Griga Posted April 23, 2014 Posted April 23, 2014 Maybe it's due to the 12-hour time format. Not enough space for displaying AM/PM. The relevant setting in the control panel -> region and language settings is the long time format - strange, because the OSD displays a short time format. But here it responds to changes of the long time format (same applies to the EPG Window). With "hh:mm:ss xx" I only get two digits, with "HH:mm:ss" all of them. I'm using the default OSD skin, and Arial Narrow is not installed on my Windows 7 PC. Please note that there is a bug in Windows 7. It sometimes takes effect if Windows 7 is pre-installed on a PC. Due to wrong registry settings the wrong time format is used, though the control panel -> region and language settings show the correct one. In this case switch to a different country, click Apply, and than back to your country, click Apply again. Quote
dvbrewer Posted April 23, 2014 Author Posted April 23, 2014 Maybe it's due to the 12-hour time format. Not enough space for displaying AM/PM. The relevant setting in the control panel -> region and language settings is the long time format - strange, because the OSD displays a short time format. But here it responds to changes of the long time format (same applies to the EPG Window). With "hh:mm:ss xx" I only get two digits, with "HH:mm:ss" all of them. I'm using the default OSD skin, and Arial Narrow is not installed on my Windows 7 PC. Please note that there is a bug in Windows 7. It sometimes takes effect if Windows 7 is pre-installed on a PC. Due to wrong registry settings the wrong time format is used, though the control panel -> region and language settings show the correct one. In this case switch to a different country, click Apply, and than back to your country, click Apply again. OK, this worked in just changing it to 24 hour clock with English (United Kingdom) setting , thanks . Quote
