mrdecoy84 Posted April 27, 2014 Posted April 27, 2014 (edited) Hello, i would report that just after the update to the new version, there wasn't any channels button on the menu bar. After a transponder scan suddenly the button appeared but it is not clickable. I don't know whether it is a bug or not, but I would appreciate some info. Thanks Edited April 27, 2014 by mrdecoy84 Quote
Griga Posted April 27, 2014 Posted April 27, 2014 It looks like the language file must be updated. The menu structure and captions have changed considerably in version 5.3.0. For overview purpose switch to English in the options, so DVBViewer uses the up-to-date English language file, and have a look at the menu related changes in the Change Log. 1 Quote
Gioxy Posted April 27, 2014 Posted April 27, 2014 I just uploaded the Italiano language file in the relevant subsection: please dowload it from this post... Enjoy 1 Quote
mrdecoy84 Posted April 28, 2014 Author Posted April 28, 2014 Ok, so the button refers to the Favourites Menu (as I can see through the english settings), but with the new language file I have still "Canali" (Channels) for the Favourites Menu. Shouldn't it be tagged "Preferiti"? Thanks a lot for your patience and good work Quote
mrdecoy84 Posted April 28, 2014 Author Posted April 28, 2014 (edited) ok I think the problem is in line 2033: Channel1.Caption=&Canali I modified it in: Channel1.Caption=&Preferiti Hope it could be helpful Edited April 28, 2014 by mrdecoy84 Quote
Gioxy Posted April 29, 2014 Posted April 29, 2014 Shouldn't it be tagged "Preferiti"? Yep... sure: many thanks for reporting it! I've replaced the language file in the post with a revised one... 1 Quote
