Recording Services takes 25% CPU time
subminiature
I installed DVBViewer Recording Services and find that when running idle for a time it then shows that it takes 25% of the CPU and the computer runs too slow to move the cursor.
Re-booting fixes the issue, but it comes back later.
I can kill the process in Task Manager as shown from the two screen shots
support.zip is over 14k and I can't upload it
thanks - I'll try that. I have deleted older support.zip and added the current one.
The Windows Media Center Receiver Service is running. And it is blocking TV cards from time to time.
disable the service or uninstall Windows Media Center.
And update to the current RS 1.29.
If this doesn't help post a new support.zip
