Screen Black
HenPen
Win 7
Nvidia GE Force 9500
DVDViewer 5.3
Starting DVBViewer with custom renderer causes the screen to be black with some shadows. The available MPEG2 decoders (Microsoft MPEG-2, CBVA DMO and LAV) do not help. [support-black.zip]
Unchecking custom renderer works fine but OSD is bad. When video is working I can check custom renderer and use OSD. [support-working.zip]
Any thoughts how to make custom render work all the time? I tried the Video Post-processor. The NVIDIA software is installed.
Thanks...
support-black.zip
support-working.zip
Hello HenPen
I face similar problems with version 5.3.0.
Black screen with German free TV channels HD. (Das Erste and ZDF). Just these channels
When I use the non HD channels everything is working.
My Graphic adapter is NVIDIA Quadro K1000M.
Do you have a solution meanwhile?
Best regards
Erhard
Fixed - it was caused by the Shader feature (contour) turned on - not sure how I did that - stupid - but maybe this helps someone else.
Great program hackbart and team (we miss Lars)
