Green backgroud with LAV
joaortnt
hi!
any one knows how to remove or change the color in the LAV codec?
i'm using the last DVBViewer with LAV codecs in "evr enhanced video renderer"
(please dont tell me to change the aspect ratio, becouse there is some channels or movies (divx) that show always the green brackgroud)
tks
have you tried already to tick "Use Custom Renderer" in Options -> DirectX,
for using the EVRCustom Video Renderer ?
What settings are you guys using in the LAV video filter? HW Acceleration with DXVA native?
For me it looks a lot like a bad/outdated graphics driver... but without any other hint from your setup I´m just speculating
I am having the same problem and that doesn't help
same for you: support.zip pls :)
