Source Specific Multicast
psangster
Would it be possible for a DVBViewer Client to join an IP Multicast Source using an IGMPv3 'join' message. I want to receive an MPEG-TS over an IP network that only supports Source Specific Multicast
I very much think the answer is no, but it's a shame that DVBViewer is geared up for this sort of thing
Thanks
You have to use TransEdit 4.0.7 from the members section, scan the MPEG-TS and export the services to the DVBViewer. TransEdit 4.0.7 is able to scan and analyze IGMPv3, DVBViewer and the Recordingservice are able to use the exported settings.
My posts are empty for some reason!!!
Therefore, it doesn't seem able to send an IGMPv3 join message for Group 239.1.1.1 specifically from unicast source 10.10.10.1
I can't see how TransEdit can be used to overcome this
Thanks
My posts are incomplete - Missing half the stuff i type in, or completely empty for some reason
The forum software hat problems with some urls (don't know why).
Remove everything that looks like a url and use the preview option before posting a reply.
