Tyro Posted May 20, 2014 Posted May 20, 2014 Trying to enter channel logos manually won´t work for me. I chose a logo and add it, but when I look in the EPG guide there are no logo for the channel i added the logo. Quote
iks-jott Posted May 20, 2014 Posted May 20, 2014 You can add and install the complete logo packs with DVBVDownloader. Quote
Tjod Posted May 20, 2014 Posted May 20, 2014 Are the *.png placed in C:\Program Files (x86)\DVBViewer\Images\Logos\ Quote
Tyro Posted May 21, 2014 Author Posted May 21, 2014 I have windows 8 and the *.png are placed in C:\Program\DVBViewer\Images\Logos\ Quote
majstang Posted May 21, 2014 Posted May 21, 2014 Trying to enter channel logos manually won´t work for me. I chose a logo and add it, but when I look in the EPG guide there are no logo for the channel i added the logo. Are you referring to the TV guide on the EPG Window or do you mean on OSD channel guide? Logos can be displayed on the OSD but no possibility to display them in the EPG Window afaik. Quote
majstang Posted May 21, 2014 Posted May 21, 2014 Ok. When you say manually adding logos you mean from Options->Channel logos right? Dont forget to press the apply button. When doing that the change is delayed and usually appears after switching channels back and forth or restart of DVBViewer. If you alrady done this maybe its a Win8 specific problem. Cant test cuz im on Win7. Quote
Tyro Posted May 21, 2014 Author Posted May 21, 2014 Ok, solved, the *.png file must be in the folder C:\Program\DVBViewer\Images\Logos\ and not in a subfolder under Logos. When I downloaded the logo files a lot of them came in subfolders like Scandinavia and so on. Quote
