DVBViewer Prof-8000 on Win 8.1 pro MCE x64 scan tp problem
Hi, after fresh installation win 8.1 pro with MCE DVBViewer with prof-8000 PCIE don't want to scan/lock transponders/freq.
Hi mixman,
the problem you're experiencing is not really related to the DVBViewer. I think it's a driver issue, because I'm having the same problems with DVBViewer and other tools aswell. It's no problem to find frequencies, symbol rates and stuff, but the card wont be able to get PAT/PMT/SDT locks. Which driver version do you use/did you try?
  • 1 month later...
Hi, sorry for delay
I tryed Driver for Win8 64 bit PTG Engine 2.0.0.5 & 2.0.0.4 for fin7 x64
