Tipiak Posted May 22, 2014 Posted May 22, 2014 Hello, I have installed the latest version of DVBViewer and now I'm not able to see this menu: How to enable this menu ? thanks!! Quote
Tjod Posted May 22, 2014 Posted May 22, 2014 Nothing has changed there in the last version. Make sure that no OSD window is open when you try to open it. And that you haven't disabled it under options > General > Control bar pop-up (it should be selected) Quote
