fozzy Posted May 29, 2014 Posted May 29, 2014 Would it be possible to make the EPG interface scroll in the X and Y axis? Currently when hovering the mouse over the channel name column its possible to scroll up and down through channels. Could you add the ability to scroll left to right when hovering the mouse over the channel description date time listing section? Also if right clicking on a program the selection menu opens would it be possible to add an option "record this series" and display an icon in the EPG description of any programs that are to be recorded? I know its possible to go into the PVR menu and select this manually although it would be a nice touch to be a one click task. If you could look at this link http://digiguide.tv/ for digiguide you will see the items Ive mentioned in use and many more which could enhance DVB? unfortunately its not compatible with DVB. Thank you in advance and for all your work to date! Quote
