Can't find channels
roeeb
I have AVerTV Volar Hybrid Q (H837). When I do a channel scan through DVBViewer or TransEdit no channels are found. Using any other software (ArgusTV, AverMedia software that comes with the USB) works fine and all channels are found.
What could be the problem? Note that DVBViewer mark it as a cable tuner card but I changed it manually to ATSC (I suppose this is because it's an hybrid card).
