Enable DVBViewer logging?
ArChie.DVB
Is it possible to enable logging in DVBViewer? I searched my harddisk, but cannot find DVBViewer log files. I am experiencing some problems with the HbbTV plugin which I like to investigate using logging.
the log files are stored in the same folder the config files are. If you click the help menu item and then the config folder item the settings directory will appear in a explorer window. To enable debug data you should start the DVBViewer with parameter -debug.
