videogamingtown Posted June 22, 2014 Posted June 22, 2014 When im scanning for channels (it can take some time) it is always on top of everything on my screen and it's impossible to easily browse the web etc etc. because i cant move it out of the way please fix this Quote
Tjod Posted June 22, 2014 Posted June 22, 2014 Disable View > Always On Top and you problem is solved. Or use TransEdit for the channel scan. Quote
videogamingtown Posted June 24, 2014 Author Posted June 24, 2014 Disable View > Always On Top and you problem is solved. Or use TransEdit for the channel scan. Ok i have another suggestion...i have a multi lnb setup so i have a lot of channels.. how about adding subfolders to the favorites lists? would make life easier for sorting them out nicely? Quote
