BBC 3 HD and BBC 4 HD
Tripitaka
Having recently installed v5.3.1.0 both BBC3HD and BBC4HD are not in the channel list. I used the update function for the .ini and re-scanned with the intention of manually adding the channels but they still do not appear in the list.
I must be doing something incorrectly as I'm sure the latest channel list from the install must include these channels.
Also, the HD channels seem to be a bit pixellated, almost like a low bitrate stream at times, maybe you can see something in my file that I can remedy this too.
Thanks.
These channels are not active during daytime.
-> settings -> filter -> DVB Source Do you see discontinuities?
I see 0 discontinuities in settings.
Later this evening I will look for these channels.
Thanks.
