Remeber Zoom for each channel
Rob66
Remember Volume for each channel is optional..
QST Is there a way to remember the zoom for each channel to?
Thx Rob
Edited by Rob66
No not per channel.
Only 4:3 and 16:9 have different settings.
And you can have different zoom presets. But you need a key pres to change them.
If you used to program Visual Basic you maybe could use the channelchange.vbs for automation for this.
(For more informations Member Seciton > Sources > DVBViewer COM Interface and DVBViewer Spy)
Your answer is clear. NO not per channel. Ok
Is it something for a DVBViewer 5.3.2 to implemented, I hope...
Thx for you quick reply Rob
