Timeline, Find More shows details.
rasmuzzen
Running latest 5.3.1 Menu - Timeline, choose a program, choose Find More, it shows Details on last viewed reocorded program. The skin is the default.
Greetings from denmark.
Edited by rasmuzzen
  • 1 month later...
This forum is strange, never get a "Yes correct", or a message "Seen the error, working on a solution for the Next release".
Greeting from Peter.
  • 2 months later...
I can confirm this bug, please fix, Find More is a useful function. THis is caused by the new skin, the old one works perfectly with Find More. Bug is also present in 5.3.2.
Thanks,
patti
Edited by patti
  • 1 month later...
Yes, thanks for confirming this.
Take the myepgsearch.XML file from the old skin,
Skin is at C:\Program Files\DVBViewer\OSDSkins\
You can take the background.png file from the old skin rename it to etc. backgroundold.png, copy it to the Graphics place, find the reference in the old XML file and change the filename reference o the old file. It is not pretty, but i Works. I really hope the Goof people behind this great software would fix this error.
Greetings and happy new year.
Edited by rasmuzzen
Yes, this was a bug inside the osd. Try this fix, until we update the DVBViewer.
osdskins.zip
  • 3 weeks later...
Thanks, but it is still not good, is shows program details (that new or what), and the future programs at the bottom, but the remote can't go Down there, and there is no colour translate (Red = record etc.).
Christian has made a new Version but there is still the background missing ;)
