peque Posted November 25, 2004 Posted November 25, 2004 Hi... I'm preparing my own logos for spain DVB-t channels... but two of them are: 3/24 K3/33 Is there any way of putting the slide in the logo filename? Or I must change channel name in the list? bye! Quote
Guest Lars_MQ Posted November 25, 2004 Posted November 25, 2004 Hi... I'm preparing my own logos for spain DVB-t channels... but two of them are: 3/24 K3/33 Is there any way of putting the slide in the logo filename? Or I must change channel name in the list? bye! It would be the easiest to change the channelnames in the Channellist. lars Quote
peque Posted November 26, 2004 Author Posted November 26, 2004 I ask if it's possible in any way... Quote
Guest Lars_MQ Posted November 26, 2004 Posted November 26, 2004 Sorry I missunderstood. You can change the channelnames in the channelwindow. Just click the channel once to highlight it and then click it again, then you should be able to edit the name. lars Quote
peque Posted November 27, 2004 Author Posted November 27, 2004 Nop... You didn't missunderstand... I'd like not to change channel name in the list... And if it would be possible to replace ilegal letters in the filename by other ones... ¿? Well, it's not important at all. Just wondering if I could leave original names and have logo displayed... bye! Quote
