serkanguzel Posted August 2, 2014 Posted August 2, 2014 Hi masters, I use Prof 7301 HD TV card. My PC system ; Intel Q6600, ATI 2400HD, 2 GB. DDR2 RAM 667 Mhz. and Windows 8 enterprise 64 bit, licensed. With BDA drivers, signal level is not realistic ; not realistic ; not realistic ; With "Dev_Bda2Driver_0.2.1.1156" realistic ; realistic ; What should I do to get the signal in DVBViewer realistic ? Regards. Quote
serkanguzel Posted August 18, 2014 Author Posted August 18, 2014 Is there anyone who can give an idea? Quote
crazycat Posted August 20, 2014 Posted August 20, 2014 Ask Prof support fir this Need improve driver, no more Quote
serkanguzel Posted August 21, 2014 Author Posted August 21, 2014 Ask Prof support fir this Need improve driver, no more Hi my master, Thank you very much, for your response. "New Driver" on request, I reported the situation to the card manufacturer ; The manufacturer, will take care of hope. But, I'm hopeless. So, for 6925 TBS "signal level status" What is ? With Prof, same ? different ? Regards. Quote
crazycat Posted August 22, 2014 Posted August 22, 2014 So, for 6925 TBS "signal level status" What is ? With Prof, same ? different ? Some different, but also not "realistic" Quote
serkanguzel Posted August 23, 2014 Author Posted August 23, 2014 Some different, but also not "realistic" Thank you very much. So my master, "Omico S2 PCI rev.3" card What is the signal level ? Realistic ? Not realisctic ? I'm living Bishkek/KYRGYZSTAN. If Signal level is realistic, here I'm thinking of ordering. http://1dvb.ru/product/kupit-omicom-s2-pci-rev3-skystar-3-pro-hd-dvb-s2/ Or which one do you recommend for realistic signal level? Regards. Quote
crazycat Posted August 24, 2014 Posted August 24, 2014 Realistic, like Technotrend devices with STm chips (S-150x, S2-3200, S2-3600, S2-3650, S2-1600). Level = SNR*5, Quality = f(BER). Thank you very much. So my master, "Omico S2 PCI rev.3" card What is the signal level ? Realistic ? Not realisctic ? Quote
crazycat Posted August 24, 2014 Posted August 24, 2014 (edited) Look like this cards not available more year. Sold out (because low-cost). You can buy TT S2-1600 - good replacement for Prof 7301 (same demod STV0903BAB, but modern tuner STV6110a instead STB6100). Device very close to Omicom S2 and possible use Omicom debug driver (handle both hardware - original and TT). And 100% support in DVBViewer, TransEdit and another software (including my own). http://www.dvbshop.net/TechnoTrend-Budget-S2-1600-HDTV-PCI-Low-Profile_1 http://1dvb.ru/product/technotrend-tt-budget-s2-1600-hdtv-pci/ http://1dvb.ru/product/kupit-omicom-s2-pci-rev3-skystar-3-pro-hd-dvb-s2/ Or which one do you recommend for realistic signal level? Edited August 24, 2014 by crazycat Quote
serkanguzel Posted August 25, 2014 Author Posted August 25, 2014 (edited) Realistic, like Technotrend devices with STm chips (S-150x, S2-3200, S2-3600, S2-3650, S2-1600). Level = SNR*5, Quality = f(BER). Look like this cards not available more year. Sold out (because low-cost). You can buy TT S2-1600 - good replacement for Prof 7301 (same demod STV0903BAB, but modern tuner STV6110a instead STB6100). Device very close to Omicom S2 and possible use Omicom debug driver (handle both hardware - original and TT). And 100% support in DVBViewer, TransEdit and another software (including my own). http://www.dvbshop.net/TechnoTrend-Budget-S2-1600-HDTV-PCI-Low-Profile_1 http://1dvb.ru/product/technotrend-tt-budget-s2-1600-hdtv-pci/ Thank you for your the valuable information. I've TechnoTrend S2-3200. But, this card, no support blind scan. Therefore, Professor 7301 I bought. I "Omicom S2" card; In addition MIS (Multi Input Stream) I thought I could watch the featured channels. TechnoTrend S2-1600 model card related issue has confused me ! I marked in the image detail, confused me !? However, these values in the other cards; for DVB-S2 45 Msymbols/s Regards. Edited August 25, 2014 by serkanguzel Quote
crazycat Posted August 26, 2014 Posted August 26, 2014 (edited) TT S2-1600 support DVB-S2 8PSK up to 45000Ks TT S2-3200, 36x0 only up to 30000Ks Edited August 26, 2014 by crazycat Quote
serkanguzel Posted August 26, 2014 Author Posted August 26, 2014 TT S2-1600 support DVB-S2 8PSK up to 45000Ks TT S2-3200, 36x0 only up to 30000Ks Wooow... To correct the information on the Internet that, thank you. TT S2-1600 still expensive. Omicom S2, according to relatively. To bring to where I live, it will be difficult. Therefore, Omicom S2 I want to get. 40 - 50 dollars a few inter-dealer found. Omicom S2, MIS (Multi Input Stream) channels, does it open ? ACM / VCM and T2 MI ? Regards. Quote
serkanguzel Posted August 26, 2014 Author Posted August 26, 2014 Wooow... To correct the information on the Internet that, thank you. TT S2-1600 still expensive. Omicom S2, according to relatively. To bring to where I live, it will be difficult. Therefore, Omicom S2 I want to get. 40 - 50 dollars a few inter-dealer found. Omicom S2, MIS (Multi Input Stream) channels, does it open ? ACM / VCM and T2 MI ? Regards. Of course, under the Windows. Quote
crazycat Posted August 27, 2014 Posted August 27, 2014 Standard version with STV0903BAC demod - so support DVB-S2 8PSK Multistream (usual with terrestrial muxes). Some early hardware comes with STV0903BAB (summer 2010, i have one) Pro version with STV0900AAC demod - additional support for 16/32APSK, ACM/VCM. T2-MI not have any relation to DVB hardware. Only soft. You can receive T2-MI with russian muxes from 49E, 55E, 90E using any DVB-S2 card and software like 4T2 Content analyzer. Omicom S2, MIS (Multi Input Stream) channels, does it open ? ACM / VCM and T2 MI ? Quote
serkanguzel Posted August 28, 2014 Author Posted August 28, 2014 Standard version with STV0903BAC demod - so support DVB-S2 8PSK Multistream (usual with terrestrial muxes). Some early hardware comes with STV0903BAB (summer 2010, i have one) Pro version with STV0900AAC demod - additional support for 16/32APSK, ACM/VCM. T2-MI not have any relation to DVB hardware. Only soft. You can receive T2-MI with russian muxes from 49E, 55E, 90E using any DVB-S2 card and software like 4T2 Content analyzer. Hi my master, Thanks again for the information. Today, from @rudi the "Omicom S2 stv0903bac", tv card I ordered. Hopefully the "bac" income. I wish, "Omicom S2 Pro" model, this wish it were more affordable. Stv0903bac is now going to be enough for me. Collectibles is growing. TT s2-3200, Prof 7301, Omicom s2 In the first stage, Hotbird the "ACM / VCM" modulated want to watch the broadcasts. Then, 90 Yamal "T2-MI" I will deal with broadcasting. Regards. Quote
