antonomium Posted August 4, 2014 Posted August 4, 2014 Hi, Two questions: 1) Has the DVBViewer Pro version support for DVB-T with SAT>IP protocol? 2) Has the free DVBViewer SAT>IP version support for DVB-T with SAT>IP protocol? I'm planning to purchase one Octopus Net with DVB-T/C tunners, but I need to confirm the DVB-T support of your software. Thank you! 1 Quote
FreakyJ Posted August 4, 2014 Posted August 4, 2014 1) yes 2) no but there is a custom DVBViewer version from dd called ddtv You csn also use vlc. Quote
antonomium Posted August 5, 2014 Author Posted August 5, 2014 1) yes 2) no but there is a custom DVBViewer version from dd called ddtv You csn also use vlc. Hi, Thank you for the response! I'm afraid that the SAT>IP free DVBViewer version has DVB-T support. I hope this will change in the future. Related to "ddtv" where can I found this? Finally, VLC can't open RTSP SAT>IP sources because VLC don't support the SAT>IP messages sequence (SETUP->PLAY->PLAY->PLAY->TEARDOWN). Quote
FreakyJ Posted August 5, 2014 Posted August 5, 2014 But the onet has also upnp support I have a dvb-c one here. So believe me Go to their site and downloads or just google. I am on my mobile right now. So I am to lazy to post the link Quote
Tjod Posted August 5, 2014 Posted August 5, 2014 I'm afraid that the SAT>IP free DVBViewer version has DVB-T support. I hope this will change in the future. This depends on SES S.A they have paid for the DVBViewer Lite Sat>IP and decide which features it should have. And SES S.A would need to request a update. Quote
FreakyJ Posted August 5, 2014 Posted August 5, 2014 Where is your problem?! http://shop.digital-devices.de/epages/62357162.sf/de_DE/?ObjectPath=/Shops/62357162/Categories/DownloadsNew1/Octopus_Net_Serie1 Here you can download DD-Tv and it works with the Onet. This is a custom DVBViewer version for DD. If you're not happy with taht you have to spend 15€ or use open source software.... Quote
