RTSP Network Device
PerryM
I have got a TBS MOI device on my network. It is working fine to XBMC via TVHeadend. I want to add it to my DVBViewer system to give two extra tuners (it already has two internal Sat tuners). I can add the device as two RTSP Network Devices in DVBViewer & RS config but in the Hardware/settings menu I am not getting any servers showing up in the window.
Can somebody suggest where I need to go next? If I get them enabled, do I need to do a new channel scan? (obviously the existing Sat tuners are already seeing the same signal since they are all fed from the same dish)
  • Like 1
The RTSP Network Device is for Sat>IP. But if i look at the TBS MOI Specification there is no standard mentioned.
http://www.tbsdtv.com/products/moi-dvb-s2-streaming-box.html
http://www.satip.info/
https://en.wikipedia.org/wiki/Sat-IP
Instead thy list only some supported clients e.g. XBMC.
If you use Sat>IP you add a device (correct IP, Ports mostly the same). And than run a channel scan if you have non for that reception type e.g. DVB-S. The Hardware works like a local DVB card.
as far as I can see tvheadend is using something which is called HTSP
https://tvheadend.org/projects/tvheadend/wiki/Htsp
If you get a HTTP link per channel. You could put them in a play-list and try open them play-list in the DVBViewer like a video file.
